1100M Advanced EDU Bundle
1100M Mill This product is required for the machine. $12,995.00
1100M Printed Manual $23.95
1100M / 1100MX Stand This product is required for the machine. $2,669.00
1100M Chip Tray This product is required for the machine. $589.00
1100M Enclosure Kit This product is required for the machine. $3,655.00
Door Lock Switch Kit This product is required for the machine. $349.00
Automatic Oiler Kit (230V) for 1100M / 1100MX This product is required for the machine. $755.00
Automatically lubricates ways on X-. Y- & Z-Axis. Ideal for environments with multiple operators where dedicated maintenance needs might be missed. Ideal for long cycle times or unattended use. Recommended with servo machines.
Lifting Bar Kit $230.00
1100M/M+/MX PathPilot Operator Console This product is required for the machine. $2,339.00
Power Drawbar Kit for 1100M / 770M This product is required for the machine. $1,399.00
12-Pocket Automatic Tool Changer for the 1100M This product is required for the machine. $5,995.00
Flood Coolant Kit (1/8 HP) for 1100M/MX and 770M/MX This product is required for the machine. $589.00
Portable Refractometer - Coolant Tester $23.95
Oil Skimmer Kit for 1100M/1100MX, 770M/770MX, and PCNC 440 This product is required for the machine. $335.00
Passive Probe Kit $509.00
Probe Stylus, 50mm Length, 6mm Ruby Ball, M4 Thread $118.00
Electronic Tool Setter with Mounting Block $1,559.00
Standard 5 in. Aluminum Soft Jaw Set $24.95
5 in. (127 mm) Parallel Set $58.95
TTS™ CNC Operator Set with Tormach Tool Assistant $1,399.00
TTS™ ER Collet Tap Holder: ER20 $213.00
ER20 Collet Set (30 Pcs.) - Inch $297.00
Huot ER20 Collet Rack $82.95
TTS™ Mini-Shear .750 in. $345.00
XDET 2.522 (Mini-Shear) Insert 10-Pack $268.00
Compact TTS™ Tool Tightening Fixture $54.95
1100M Extended Warranty $795.00
More Info In Stock
More Info In Stock
* Required Fields
Machine Dimentions
X-Axis: 18 in.(457 mm)
Y-Axis: 11 in. (279 mm)
Z-Axis: 16.25 in. (412 mm)
Spindle Power: 2 hp (1.5 kW)
Maximum Speed: 7500 RPM
Transmission: Poly-V belt
Spindle Taper: R8
Maximum Feed Rate
Z-Axis: 90 IPM (2.29 m/min)
PATHPILOT® Controller
80GB program memory
Assembly
1100M Assembly is available for $2,995 .
Technical Specifications
Machine Dimentions
Spindle Taper: R8
Maximum Feed Rate
80GB program memory
Assembly
