1100M Advanced EDU Bundle
1100M Mill This product is required for the machine. $10,995.00
1100M Printed Manual $19.95
1100M / 1100MX Stand This product is required for the machine. $2,295.00
1100M Chip Tray This product is required for the machine.
1100M Enclosure Kit This product is required for the machine. $3,095.00
Door Lock Switch Kit This product is required for the machine. $295.00
Automatic Oiler Kit (230V) for 1100M / 1100MX This product is required for the machine. $645.95
Automatically lubricates ways on X-. Y- & Z-Axis. Ideal for environments with multiple operators where dedicated maintenance needs might be missed. Ideal for long cycle times or unattended use. Recommended with servo machines.
Lifting Bar Kit $195.00
1100M/M+/MX PathPilot Operator Console This product is required for the machine. $1,795.00
Power Drawbar Kit for 1100M / 770M This product is required for the machine. $1,195.00
12-Pocket Automatic Tool Changer for the 1100M This product is required for the machine. $5,775.00
Flood Coolant Kit (1/8 HP) for 1100M/MX and 770M/MX This product is required for the machine. $499.95
Portable Refractometer - Coolant Tester $19.95
Oil Skimmer Kit for 1100M/1100MX, 770M/770MX, and PCNC 440 This product is required for the machine. $279.95
Passive Probe Kit $429.95
Electronic Tool Setter $1,295.00
Professional Metalworking Gauge Kit $379.95
5 in. (127 mm) CNC Vise $499.95
Standard 5 in. Aluminum Soft Jaw Set $22.95
Clamp Kit for 5/8 in. T-Slots (58 Pcs.) $89.95
5 in. (127 mm) Parallel Set $49.95
TTS™ CNC Operator Set with Tormach Tool Assistant $1,195.95
TTS™ ER Collet Tap Holder: ER20 $189.95
ER20 Collet Set (30 Pcs.) $249.95
Huot ER20 Collet Rack $69.95
TTS™ MiniShear .750 in. $289.95
XDET 2.522 (Mini-Shear) Insert 10-Pack $224.95
Compact TTS™ Tool Tightening Fixture $45.95
End Mill Kit for Aluminum #1 $499.95
1100M Extended Warranty $795.00
More Info Stock: In Stock
* Required Fields
Technical Specifications
Machine Dimentions
X-Axis: 18 in.(457 mm)
Y-Axis: 11 in. (279 mm)
Z-Axis: 16.25 in. (412 mm)
Spindle Power: 2 hp (1.5 kW)
Maximum Speed: 7500 RPM
Transmission: Poly-V belt
Spindle Taper: R8
Maximum Feed Rate
Z-Axis: 90 IPM (2.29 m/min)
Assembly
