1100M Basic EDU Bundle
1100M Mill This product is required for the machine. $10,995.00
1100M Printed Manual
1100M / 1100MX Stand This product is required for the machine. $2,295.00
1100M Chip Tray This product is required for the machine.
1100M Enclosure Kit This product is required for the machine. $3,095.00
Door Lock Switch Kit This product is required for the machine. $295.00
Manual Oil Pump This product is required for the machine.
Lubricates ways on X-. Y- & Z-Axis. Requires manual pumping (x3) per 8 hour shift. Not recommended for unattended machining.
Lifting Bar Kit $195.00
PathPilot Controller This product is required for the machine. $495.00
PathPilot Controller Vesa Mount This product is required for the machine.
Standard LCD Monitor This product is required for the machine. $279.95
Jog Shuttle Controller This product is required for the machine. $99.95
Controller Arm This product is required for the machine. $359.95
5 in. (127 mm) CNC Vise $499.95
Clamp Kit for 5/8 in. T-Slots (58 Pcs.) $89.95
5 in. (127 mm) Parallel Set $49.95
TTS™ CNC Operator Set with Tormach Tool Assistant $1,195.95
End Mill Kit for Aluminum #1 $499.95
Drawbar Wrench/Hammer $31.95
Compact TTS™ Tool Tightening Fixture $45.95
1/2 in. Shank Edge Finder $14.95
Professional Metalworking Gauge Kit $379.95
3/8 in. Shank Edge Finder $13.95
1100M Extended Warranty $795.00
More Info Stock: In Stock
* Required Fields
Technical Specifications
Machine Dimentions
X-Axis: 18 in.(457 mm)
Y-Axis: 11 in. (279 mm)
Z-Axis: 16.25 in. (412 mm)
Spindle Power: 2 hp (1.5 kW)
Maximum Speed: 7500 RPM
Transmission: Poly-V belt
Spindle Taper: R8
Maximum Feed Rate
Z-Axis: 90 IPM (2.29 m/min)
Assembly
