1100M Intermediate EDU Bundle
1100M Mill This product is required for the machine. $12,450.00
1100M Printed Manual $22.95
1100M / 1100MX Stand This product is required for the machine. $2,565.00
1100M Chip Tray This product is required for the machine. $565.00
1100M Enclosure Kit This product is required for the machine. $3,475.00
Door Lock Switch Kit This product is required for the machine. $335.00
Automatic Oiler Kit (230V) for 1100M / 1100MX This product is required for the machine. $725.00
Automatically lubricates ways on X-. Y- & Z-Axis. Ideal for environments with multiple operators where dedicated maintenance needs might be missed. Ideal for long cycle times or unattended use. Recommended with servo machines.
Lifting Bar Kit $221.00
1100M/M+/MX PathPilot Operator Console This product is required for the machine. $2,245.00
Power Drawbar Kit for 1100M / 770M This product is required for the machine. $1,345.00
Flood Coolant Kit (1/8 HP) for 1100M/MX and 770M/MX This product is required for the machine. $565.00
HAIMER 3D-Sensor New Generation Kit (Metric) $655.00
Metric Ball Replacement Tip for Haimer Zero Master/ 3D Sensor $59.95
Clamp Kit for 5/8 in. T-Slots (58 Pcs.) $96.95
5 in. (127 mm) Parallel Set $56.95
TTS™ CNC Operator Set with Tormach Tool Assistant $1,345.00
1/16 in. - 1/2 in. Machine Length Drill Set $211.00
TTS™ ER Collet Tap Holder: ER20 $205.00
ER20 Collet Set (30 Pcs.) - Inch $286.00
Compact TTS™ Tool Tightening Fixture $52.95
End Mill Kit for Aluminum #1 $535.00
PathPilot Software Bootable USB Drive - Recovery Media $28.95
1100M Extended Warranty $795.00
More Info In Stock
More Info In Stock
* Required Fields
Machine Dimentions
X-Axis: 18 in.(457 mm)
Y-Axis: 11 in. (279 mm)
Z-Axis: 16.25 in. (412 mm)
Spindle Power: 2 hp (1.5 kW)
Maximum Speed: 7500 RPM
Transmission: Poly-V belt
Spindle Taper: R8
Maximum Feed Rate
Z-Axis: 90 IPM (2.29 m/min)
PATHPILOT® Controller
80GB program memory
Assembly
1100M Assembly is available for $2,995 .
Technical Specifications
Machine Dimentions
Spindle Taper: R8
Maximum Feed Rate
80GB program memory
Assembly
