Tormach will be closed on Friday, March 29th in celebration of Good Friday. We will reopen at 8 am CST on Monday, April 1st.
1100MX Advanced EDU Bundle
1100MX Mill This product is required for the machine. $23,995.00
1100MX Mill package automatically includes stand, chip pan, enclosure, power draw bar and machine owner's kit. These items are pre-selected for you in the machine builder.
1100M / 1100MX Stand This product is required for the machine. $0.00
1100MX Chip Tray This product is required for the machine. $0.00
This is the base around the machine. It helps capture and collect chips and coolant.
1100MX Enclosure Kit This product is required for the machine. $0.00
Door Lock Switch Kit This product is required for the machine. $295.00
Automatic Oiler Kit (230V) for 1100M / 1100MX This product is required for the machine. $645.95
Automatically lubricates ways on X-. Y- & Z-Axis. Ideal for environments with multiple operators where dedicated maintenance needs might be missed. Ideal for long cycle times or unattended use. Recommended with servo machines.
Lifting Bar Kit $195.00
1100MX Printed Manual $19.95
1100M/M+/MX PathPilot Operator Console This product is required for the machine. $1,795.00
Flood Coolant Kit (1/8 HP) for 1100M/MX and 770M/MX This product is required for the machine. $499.95
Portable Refractometer - Coolant Tester $19.95
Oil Skimmer Kit for 1100M/1100MX, 770M/770MX, and PCNC 440 This product is required for the machine. $279.95
12-Pocket Automatic Tool Changer for the 1100MX (BT30) This product is required for the machine. $5,950.00
Passive Probe Kit (BT30) $439.95
Replacement Probe Tip $99.95
Electronic Tool Setter $1,295.00
Professional Metalworking Gauge Kit $379.95
5 in. (127 mm) CNC Vise $499.95
Standard 5 in. Aluminum Soft Jaw Set $22.95
5 in. (127 mm) Parallel Set $49.95
Clamp Kit for 5/8 in. T-Slots (58 Pcs.) $89.95
ER20 Collet Set (30 Pcs.) $249.95
BT30 Operator's Kit (Inch) $1,299.95
End Mill Kit for Aluminum #1 $499.95
Huot ER20 Collet Rack $69.95
1100MX Extended Warranty $995.00
PathPilot HUB CNC Simulator - Unlimited Seats $0.00
More Info Stock: In Stock
* Required Fields
X-Axis: 18 in. (457 mm)
Y-Axis: 11 in. (279 mm)
Z-Axis: 16.25 in. (413 mm)
Spindle Power: 2 hp / 1.49 kW
Maximum Speed: 10,000 RPM
Transmission: Poly-V belt
Spindle Taper: BT30
Maximum Feed Rate
Z-Axis: 230 IPM (5.84 m/min)
Power Required: Single-Phase 230 Vac, 50/60Hz, 20A breaker
Table Size: 34 in. × 9.5 in. (863 mm x 241 mm)
Spindle Nose to Table Max Clearance: 17.25 in. (438 mm)
Spindle Centerline to Machine Column: 11 in. (279 mm)
Frame
1-Year Warranty against defects in material and workmanship. Extended Warranty available.
Assembly
