1100MX Basic EDU Bundle
1100MX Mill This product is required for the machine. $24,995.00
1100MX Mill package automatically includes stand, chip pan, enclosure, power draw bar and machine owner's kit. These items are pre-selected for you in the machine builder.
1100M / 1100MX Stand This product is required for the machine.
1100MX Chip Tray This product is required for the machine.
This is the base around the machine. It helps capture and collect chips and coolant.
1100MX Enclosure Kit This product is required for the machine.
Automatic Oiler Kit (230V) for 1100M / 1100MX This product is required for the machine. $725.00
Automatically lubricates ways on X-. Y- & Z-Axis. Ideal for environments with multiple operators where dedicated maintenance needs might be missed. Ideal for long cycle times or unattended use. Recommended with servo machines.
Door Lock Switch Kit This product is required for the machine. $335.00
Lifting Bar Kit $221.00
1100MX Printed Manual $22.95
PathPilot Controller This product is required for the machine. $1,015.00
PathPilot Controller Vesa Mount This product is required for the machine.
Touch Screen Kit This product is required for the machine. $519.00
Controller Arm This product is required for the machine. $409.00
Jog Shuttle Controller This product is required for the machine. $113.00
Haimer 3D Sensor Kit (BT30) $579.00
Metric Ball Replacement Tip for Haimer Zero Master/ 3D Sensor 2 x $59.95
5 in. (127 mm) Parallel Set $56.95
Clamp Kit for 5/8 in. T-Slots (58 Pcs.) $96.95
1/16 in. - 1/2 in. Machine Length Drill Set $211.00
BT30 Operator's Kit (Inch) $1,395.00
PathPilot Software Bootable USB Drive - Recovery Media $28.95
1100MX Extended Warranty $995.00
More Info In Stock
More Info In Stock
* Required Fields
1100MX TECHNICAL SPECIFICATIONS
X-Axis: 18 in. (457 mm)
Y-Axis: 11 in. (279 mm)
Z-Axis: 16.25 in. (413 mm)
Spindle Power: 2 hp / 1.49 kW
Maximum Speed: 10,000 RPM
Transmission: Poly-V belt
Spindle Taper: BT30
Maximum Feed Rate
Z-Axis: 230 IPM (5.84 m/min)
Power Required: Single-Phase 230 Vac, 50/60Hz, 20A breaker
Frame
Table Size: 34 in. × 9.5 in. (863 mm x 241 mm)
Spindle Nose to Table Max Clearance: 17.25 in. (438 mm)
Spindle Centerline to Machine Column: 11 in. (279 mm)
1-Year Warranty against defects in material and workmanship. Extended Warranty available.
Assembly
As the default, Tormach equipment is shipped in crates and owners assemble and commission machines. But we recognize the demand for turn-key machines so that's why we offer machine assembly as an add-on service. A Tormach professional installs, aligns, and tests major componenets, allowing you to quickly commission you machine once it arrives.
1100MX Assembly is available for $2,995 .
Spindle Taper: BT30
Maximum Feed Rate
Frame
PATHPILOT® Controller
80GB program memory
Assembly
