1300PL Intermediate EDU Bundle
1300PL Plasma Table This product is required for the machine. $13,950.00
1300PL Owner's Kit This product is required for the machine.
The Owner's Kit for the 1300PL contains the small parts needed to set up a new machine, along with spare hardware and the owner's manual.
More Info In Stock
Powermax65 SYNC Hypertherm plasma cutter This product is required for the machine. $4,500.00
Hypertherm cartridge: SmartSYNC or adapter 65A mechanized cutting This product is required for the machine. $62.95
Hypertherm Ohmic Touchoff Ring This product is required for the machine. $13.95
Hypertherm Shade 8 Face Shield This product is required for the machine. $83.95
PathPilot Controller This product is required for the machine. $1,015.00
Controller Arm This product is required for the machine. $409.00
Touch Screen Kit This product is required for the machine. $519.00
Jog Shuttle Controller This product is required for the machine. $113.00
PathPilot Controller Vesa Mount This product is required for the machine. $22.95
PathPilot Software Bootable USB Drive - Recovery Media $28.95
1300PL Plasma Table Extended Warranty $795.00
More Info In Stock
* Required Fields
1300PL PLASMA TABLE TECHNICAL SPECIFICATIONS
Travels:
X-Axis: 48.5 in. (1270 mm)
Y-Axis: 50 in. (1308 mm)
Spindle Nose: 5C>Z-Axis: 3.9 in. (100 mm)
Maximum Feed Rate
X- and Y-Axis: 1,000 IPM (25.4 m/min)
Z-Axis: 120 IPM (3.0 m/min)
X- , Y- and Z-Axis: Acceleration Rate (30 in/second^2)
Table Specifications
Table Size: 51.2 in. × 51.2 in. (1.3 m × 1.3 m)
Table Type: Water Table
Material Weight Capacity: 750 lbs. (340 kg)
Liquid Capacity: 59 US Gallons (223 liters)
Machine Footprint: 78 in. × 70 in. (1.95 m × 1.7 m)
Overall System Height: 55 in. (1.4 m)
Typical System Weight: 1,232 lbs. (559 kg)
Linear Motion Components
X- and Y-Axis Motor: Servo-Driven
Z-Axis Motor: NEMA-23 Stepper
Power Transmission: Planetary Gear (X-Axis) 5 mm HTD Belt (Y-Axis)
Machine Construction
Water Table: Welded Steel
Machine Base: Welded Steel
Gantry Bridge: Aluminum
Gantry Supports: Steel
Shop Requirements
Power Required: Single-Phase 230 Vac, 50/60 Hz, 20A breaker
Air Pressure: Between 90 - 120 psi (620 kPa - 825 kPa) @ 6.7 CFM. If the air supply is more than 120 psi (825 kPa), you must use a regulator.
Resolution And Accuracy
Resolution: 0.0005 in. (.0127 mm)
Repeatability: ±0.001 in. (±0.0254 mm)
Positional Accuracy: ≤0.005 in. / ft (130 micron / 300mm)
PathPilot® Controller
User-friendly design
Free Simulator via PathPilot HUB
DXF import capability
Built-in shape library
Built-in auto cut feeds & speeds calculator
80 GB of available space for G-Code
Torch
Plasma Source Options: Hypertherm Options: Powermax45 SYNC, Powermax65 SYNC, Powermax85 SYNC, Powermax105 SYNC
Torch Type: Floating Head with Digital Torch Height Control
Torch Features: Breakaway Torch, Collision Detection
Torch Height Control: Velocity Locking
Delivery Notes And Warranty
Lift-Gate Deliverable: Yes - Forklift Not Required
Required Equipment: Pallet Jack - Engine Hoist or Gantry Crane
Warranty: 1 Year Warranty against defects in material and workmanship. Extended Warranty available.
Travels:
Maximum Feed Rate
Shop Requirements
Torch
Plasma Source Options: Hypertherm Options: Powermax45, Powermax65 SYNC, Powermax85 SYNC, Powermax105 SYNC
