1500MX Chip Conveyor Kit
$4,995.00
445 lbs.
1500MX Chip conveyor add-on kit for flood coolant system.
Compatability:
- 1500MX Flood Coolant required.
Key Benefits:
- No more worries about chip buildup in the filter baskets
- Runs on conventional, 220V household power
- Programmable run duration allows coolant to drain back into the tank before discharging chips
- Replaceable Stainless Steel Chip Filter Screens
- 1CR13 Stainless Steel Conveyor Chain Belt
- Serated and Flat Wavy Cleats
- Incline Angle: 60 degrees
- Integrated clutch system to prevent damage from jammed debris
- Variable speed 0.4kW Motor
Keep your Tormach 1500MX mill’s chip pan clean with our new conveyor kit. The conveyor slots right into the flood coolant tank to provide an easy to use, automatic, chip removal system. The conveyor can be activated manually by a button in PathPilot or via m-code which allows for timed, programmable control over your chip management.
Note: Photos include the 1500MX Flood Coolant Kit (PN 51567), which is required for use of the Chip Conveyor kit.
Specifications
- Electrical: 220V @ 5A - ships with NEMA 6-20 plug
