1500MX CNC Mill Configurator
1500MX - Self-Assembled $32,995.00
<p>Includes 1500MX CNC mill, PathPilot operator console, and mill enclosure. This option is self-assembled by the customer.</p>
$5,565.00
16-Pocket Automatic Tool Changer for the 1500MX $5,565.00
$2,889.00
1500MX Flood Coolant Kit $2,889.00
Additional Options:
1500MX-Factory-Assembled w/ATC & Coolant System $42,995.00
<p>Includes everything in the base machine (mill, operator console, and enclosure) plus an automatic tool changer and flood coolant system. All fully assembled.</b><p><b><span style="color:red;">Please note:</span> </b> customer must have a forklift or loading dock for unloading the crate.</p>
More Info In Stock
16-Pocket Automatic Tool Changer: 1500MX
More Info In Stock
Related items:
Wireless Probe and Tool Setter Kit $5,950.00
Probe Stylus, 50mm Length, 6mm Ruby Ball, M4 Thread $118.00
Recommended items:
Haimer 3D Sensor Kit (BT30) $579.00
Metric Ball Replacement Tip for Haimer Zero Master/ 3D Sensor $61.95
Recommended items:
Adding a microARC 6 fourth axis to your Tormach Mill
The microARC6 4th Axis
Looking to take your Tormach 1500MX to the next level? Add our 4th axis and you'll be able to create more complex parts as it allows to cut along the arc of your workpiece. The 4th axis also makes it possible to access more sides and angles without having to manually move the piece into a separate fixture.
microARC6
microARC 6 - 150mm Rotary Table Kit for 1500MX $7,450.00
microARC 6 Subplate $235.00
Adjustable Tailstock (Medium) $179.00
Additional Options:
Coolant Options for the 1500MX CNC Mill
Coolant System Options
The Tormach 1500MX CNC Mill has multiple options when it comes to coolant. The flood coolant system is efficient at chip removal, lubrication, and heat management. Optional washdown bars keep chips from building up in the enclosure. Also available is a minimum quantity lubrication (MQL) system.
Coolant Options
Through Spindle Coolant Kit, 1500MX $7,450.00
MQL Full Kit - 1500MX $1,229.00
Automatic Chip Tray Washdown Bar Kit $2,354.00
Requires 1500MX Flood Coolant Kit (PN 51567) when purchased with the self-assembled base machine.
Coolant Filter Assembly for 1500MX
Mist Collector, 420cfm $2,139.00
Portable Refractometer - Coolant Tester $23.95
1500MX Chip Conveyor Kit $4,995.00
1500MX Machine Way Oil (Citgo EP Compound 220), 1 GAL $41.95
Waterproof Mouse $28.95
Waterproof Mini-Keyboard $48.95
Tool Storage Rack Assembly, 1500MX $349.00
USB Camera for PathPilot-Controlled Machines $82.95
California Air Tools 4610XC Air Compressor $399.00
1500MX Extended Warranty $1,595.00
More Info In Stock
On-site Service Quote Request
On-site machine installation and training is available for an additional charge ($2,000 reservation fee + $2,000 per day of service) when purchasing a new machine. Check the box to quote this service.
6 in. CNC Vise - Precision Angle Lock $585.00
TalonGrip / VersaGrip Vice Jaws - Mitee-Bite PN 33006 - Not Compatible with Tormach 5 $419.00
TalonGrip 6 $208.00
Hardened 6 in Steel Jaw Set $78.95
Standard 6 in. Aluminum Soft Jaw Set $29.95
6 in. Parallel Set $63.95
Adjustable Parallel Set $51.95
Recommended items:
1-2-3 Block Set $29.95
5/8 in. T-Slot Nut with Locating Pin (Blind) $14.95
5/8 in. T-Slot Nut with Locating Pin $14.95
5/8 in. T-Slot Nut with Locating Stop $12.95
T-Slot Bridge Nut for PCNC 1100, 1100M & 1100MX $32.95
T-Slot Clamp Set $140.00
5/8 in. T-Slot Nut $7.95
1/2-13 Flanged Nut $4.95
Recommended items:
SMW Fixture Tooling Plate for 1500MX (4140 Steel)
Includes fixture tooling plate (PN 51514) bundled with mounting hardware and the most popular fixturing accessories (PN 52220).
Fixture Tooling Plate Accessory Upgrade Kit $635.00
1500MX Fixture Tooling Plate Accessory Kit $645.00
Includes mounting hardware and SMW Basic Accessory Kit.
Related items:
SMW Fixture Tooling Plate for 1500MX (Aluminum, Black Anodized 7075)
Includes fixture tooling plate (PN 51798) bundled with mounting hardware and the most popular fixturing accessories (PN 52220).
Related items:
Stop-Loc Setup Tool $20.95
Starter BT30 Toolholding Set
BT30 Tool Holder, Drill Chuck 8mm, 80mm $124.00
BT30 Tool Holder, End Mill 1/4 in, 50mm $63.95
BT30 Tool Holder, End Mill 3/8 in, 50mm $63.95
BT30 Tool Holder, End Mill 1/2 in, 50mm $63.95
BT30 Tool Holder, ER20, 48mm Guage Length $67.95
30 mm Wrench for TTS™-ER20 Nut $10.95
Socket, BT30 Pull Stud $58.95
ER20 Collet - 1/8 in. $11.95
ER20 Collet - 1/4 in. $11.95
ER20 Collet - 3/8 in. $11.95
Pull Stud, BT30 45-Degree $8.95
Deluxe BT30 Toolholding Set
BT30 Tool Holder, ER20, 60mm Gage Length $64.95
ER20 Collet - 1/2 in. $11.95
Tool Tightening Fixture, BT30 $55.95
BT30 Tool Tray Assembly, 12 Tool $35.95
Spindle Cleaner, BT30 $11.95
ER20 Toolholder 5 Pack
ER16 Toolholder 5 Pack
BT30 Tool Holder, ER16, 60mm Gage Length $67.95
ER16M Collet Nut Wrench $19.95
ER20 Collet Variety Pack (20 Pcs.) - Inch
ER16 Collet Variety Pack (15 Pcs.) - Inch
ER16 Collet - 1/8 in. $11.95
ER16 Collet - 1/4 in. $11.95
ER16 Collet - 3/8 in. $11.95
ER20 Collet Set (15 Pcs.) - Inch $118.00
ER20 Collet Set (30 Pcs.) - Inch $297.00
ER16 Collet Set (22 Pcs.) - Inch $235.00
ER20/ER16 Deluxe Wrench Set $41.95
BT30 Tool Holder, Drill Chuck 8mm, 80mm 2  x  $124.00
BT30 Tool Holder, End Mill 3/8 in, 50mm 2  x  $63.95
ER20 Collet - 1/8 in. 2  x  $11.95
ER20 Collet - 1/4 in. 2  x  $11.95
ER20 Collet - 3/8 in. 2  x  $11.95
Pull Stud, BT30 45-Degree 10  x  $8.95
BT30 Tool Holder, ER20, 60mm Gage Length 8  x  $64.95
ER20 Collet - 1/2 in. 2  x  $11.95
BT30 Tool Holder, ER20, 48mm Guage Length 5  x  $67.95
BT30 Tool Holder, ER16, 60mm Gage Length 5  x  $67.95
ER16 Collet - 1/8 in. 5  x  $11.95
ER16 Collet - 1/4 in. 5  x  $11.95
ER16 Collet - 3/8 in. 5  x  $11.95
BT30 Tool Holder, End Mill 6mm, 50mm Gage Length $60.95
BT30 Tool Holder, End Mill 10mm, 50mm Gage Length $60.95
ER20 Collet - 4 mm $11.95
ER20 Collet - 6 mm $11.95
ER20 Collet - 10 mm $11.95
Deluxe BT30 Toolholding Set (Metric)
ER20 Collet - 12 mm $11.95
ER16 Collet Set (12 Pcs.) - Metric $174.00
ER20 Collet Set (14 Pcs.) - Metric $257.00
BT30 Tool Holder, End Mill 6mm, 50mm Gage Length 2  x  $60.95
BT30 Tool Holder, End Mill 10mm, 50mm Gage Length 2  x  $60.95
BT30 Tool Holder, ER20, 48mm Guage Length 2  x  $67.95
ER20 Collet - 4 mm 4  x  $11.95
ER20 Collet - 6 mm 4  x  $11.95
ER20 Collet - 10 mm 4  x  $11.95
ER20 Collet - 12 mm 2  x  $11.95
Pull Stud, BT30 45-Degree 16  x  $8.95
ER16 TSC Sealed Collet Set (17 Pcs.) - Inch $325.00
ER16 TSC Sealed Collet Set (8 Pcs.) - Metric $156.00
ER20 TSC Sealed Collet Set (25 Pcs.) - Inch $469.00
ER20 TSC Sealed Collet Set (11 Pcs.) - Metric $212.00
Pull Stud, BT30-45 deg., Thru Spindle Coolant (TSC) $14.95
When using Through Spindle Coolant (TSC), one TSC Pull Stud is required for each BT-30 toolholder.
Face Mill 38mm Kit
Face Mill - 38 mm $224.00
BT30 Tool Holder, Face Mill Arbor 1/2 in, 35mm $87.95
Carbide Insert for Steel - Face & End Mills 10-Pack $51.95
Carbide Insert for Aluminum and Plastic - Face & End Mills 10-Pack $152.00
Related items:
Face Mill 1 1/2 in. Kit
Face Mill - 1 1/2 in. $268.00
Carbide Insert for Aluminum and Plastic - Face Mill/Fly Cutter 10-Pack $110.00
Carbide Insert for Steel - Face Mill/Fly Cutter 10-Pack $96.95
Related items:
YG-1 V7 Plus A Series Steel, Cast Iron & Stainless End Mill Kit $705.00
USB M-Code I/O Interface Kit $309.00
More Info In Stock
More Info In Stock
Free SprutCAM 3 Month Trial
More Info In Stock
Anti-Fatigue Tormach Logo Mat $58.95
36 in. x 24 in. Satin Tormach Banner with Top Grommets $27.95
PathPilot Keyboard Shortcuts Mousepad $16.95
* Required Fields
1500MX CNC MILL TECHNICAL SPECIFICATIONS
X-Axis: 19.7 in. (500 mm)
Y-Axis: 13.8 in. (350 mm)
Z-Axis: 14 in. (356 mm)
Spindle Nose to Table: 3.7-17.7 in. (96-450 mm)
Continuous Power: 4 hp (3 kW)
Peak Power: 6hp (4.5 kW)
Spindle Speed: 250-10,000 RPM
Spindle Taper: BT30 (sealed bearing)
Thread Machining: Rigid Tapping
Maximum Feed Rates
X- and Y-Axis: 1,200 IPM (30.5 m/min)
Z-Axis: 600 IPM (15.2 m/min)
Power and Air
Power Required: Single-Phase 230 Vac, 50/60 Hz, 30A breaker
Plug Type: NEMA L6-30P
Air Required: 90-120 psi
Table Size: 35 in. × 12.75 in. (0.9 m × 0.3 m)
Typical System Footprint: 86 in. × 104 in. × 94 in.(2.2 m × 2.6 m × 2.4 m)
Typical System weight: 2800 lbs. (1270 kg)
Maximum Weight on Table: 300 lbs. (136 kg)
Performance
Testing: Ballbar testing on every machine
Key Components
Frame: Bonded epoxy granite base and column castings
Ways: Linear rails
Motion System: EtherCAT control system
Shipping
Pallet Weight: Factory Assembled: 3210 lbs. (1456 kg) / Self Assembled: 2650 lbs. (1202 kg)
Crate Dimensions: Factory Assembled: 68 in. × 74 in. × 89 in. (1.7 m × 1.9 m × 2.3 m) / Self Assembled: 54 in. × 58 in. × 89 in.(1.4 m × 1.5 m × 2.3 m)
Optional Accessories
16-pocket automatic tool changer (ATC)
microARC 6 – 6 in. (150 mm) 4th axis rotary table
36-gallon flood coolant tank and manual sprayer
Automatic enclosure washdown system
Wireless probe and tool setter
MQL system
Through-spindle coolant
Mist collector
Chip conveyor system
1-year warranty against defects in material and workmanship. Extended warranty available.
Travels:
Spindle Taper: BT30
Maximum Feed Rates
Power and Air
Performance
Key Components
Ways: Linear rails
Shipping
Please Note: The customer must have a forklift or loading dock to unload the crate.
MQL system
Mist collector
Chip conveyor system (under development)
Tormach Troubleshooting
LOOKING FOR HELP WITH YOUR 1500MX?
Visit the Tormach Support Site to find Manuals, Technical Documents, Datasheets, Service Bulletins, The Knowledge Base and Troubleshooting Guides.
View Our Support Section
