15L Advanced EDU Bundle
15L Slant-PRO CNC Lathe This product is required for the machine. $19,450.00
15L Printed Manual $22.95
Automatic Oiler Kit (230V) for PCNC 1100 / 15L This product is required for the machine. $725.00
Light Kit for Tormach 15L Slant-PRO This product is required for the machine. $183.00
Lifting Kit for Tormach 15L Slant-PRO $375.00
PathPilot Controller for PCNC Mills and 15L Lathe This product is required for the machine. $1,015.00
Controller Arm This product is required for the machine. $409.00
Touch Screen Kit This product is required for the machine. $519.00
Jog Shuttle Controller This product is required for the machine. $113.00
Deluxe Lathe Tool Starter Kit $1,119.00
Turret Kit for Tormach 15L Slant-PRO This product is required for the machine. $4,850.00
3-Jaw Reversible 6 in. Lathe Chuck (D1 Type Direct Mount) This product is required for the machine. $559.00
Automatic Collet Closer for 15L Slant-PRO This product is required for the machine. $2,845.00
5C Round Collet Set (35 Pcs.) - Inch $335.00
Huot 5C Collet Rack $45.95
EZ-Puller with 3/4 $929.00
Floating Tramp Oil Collection Pillow This product is required for the machine. $14.95
9 Inch Length Coolant Nozzle for Turret 10-Pack This product is required for the machine. $56.95
Filter/Regulator/Lubricator (FRL) This product is required for the machine. $67.95
Basic 3 Piece Indicator Set $150.00
Stop-Loc Setup Tool $22.95
Haimer CENTRO Precision Centering Device $799.00
5 mm Bent Probe Tip for Haimer CENTRO $94.95
PathPilot Software Bootable USB Drive - Recovery Media $28.95
15L Slant-PRO Extended Warranty $795.00
More Info In Stock
More Info In Stock
* Required Fields
Z-Axis Travel: 12 (305 mm)
Coolant Tank Size: 10 gallon
Motion
Spindle Power: 3 hp (2.24 kW)
Spindle Speed:
  • Low: 180 to 2,500 RPM
  • High: 250 to 3,500 RPM
Control
Optional Accessories
8-Station turret
Quick-change tool post
Gang tooling system
Automatic 5C collet closer
Features: 80GB program memory
Assembly
15L Slant-PRO CNC Lathe assembly pricing is available for $2,995 .
Motion
Spindle Speed:
Control
8-Station turret
Gang tooling system
Assembly
