Tormach will be closed on Friday, March 29th in celebration of Good Friday. We will reopen at 8 am CST on Monday, April 1st.
15L Advanced EDU Bundle
15L Slant-PRO CNC Lathe This product is required for the machine. $17,245.00
15L Printed Manual $19.95
Sealant, Sikaflex 1a, 300mL Cartridge, Black This product is required for the machine. $0.00
Lathe Test Piece Kit. This product is required for the machine. $0.00
Automatic Oiler Kit (230V) for PCNC 1100 / 15L This product is required for the machine. $645.95
Light Kit for Tormach 15L Slant-PRO This product is required for the machine. $159.95
Lifting Kit for Tormach 15L Slant-PRO $329.95
PathPilot Controller for 15L Lathe and PCNC Mills This product is required for the machine. $495.00
Controller Arm This product is required for the machine. $359.95
Touch Screen Kit This product is required for the machine. $459.95
Jog Shuttle Controller This product is required for the machine. $99.95
Cord, Power 115 VAC 18AWG 6ft This product is required for the machine. $0.00
Cable, Monitor Power Extension 6 ft (combo male/female end) This product is required for the machine. $0.00
Power Strip 3 AC Kit for 15L This product is required for the machine. $0.00
Deluxe Lathe Tool Starter Kit $995.95
Turret Kit for Tormach 15L Slant-PRO This product is required for the machine. $4,495.00
3-Jaw Reversible 6 in. Lathe Chuck (D1 Type Direct Mount) This product is required for the machine. $495.00
Automatic Collet Closer for 15L Slant-PRO This product is required for the machine. $2,695.00
5C Round Collet Set (35 Pcs.) $295.00
Huot 5C Collet Rack $40.95
EZ-Puller with 3/4 $714.95
Floating Tramp Oil Collection Pillow This product is required for the machine. $12.95
9 Inch Length Coolant Nozzle for Turret 10-Pack This product is required for the machine. $49.95
Filter/Regulator/Lubricator (FRL) This product is required for the machine. $59.95
Stop-Loc Setup Tool $19.95
Haimer CENTRO Precision Centering Device $725.00
5 mm Bent Probe Tip for Haimer CENTRO $83.00
15L Slant-PRO Extended Warranty $795.00
More Info Stock: In Stock
PathPilot HUB CNC Simulator - Unlimited Seats $0.00
* Required Fields
TECHNICAL SPECIFICATIONS
Z-Axis Travel: 12 (305 mm)
Coolant Tank Size: 10 gallon
Motion
Spindle Power: 3 hp (2.24 kW)
Spindle Speed:
  • Low: 180 to 2,500 RPM
  • High: 250 to 3,500 RPM
Control
Optional Accessories
8-Station turret
Quick-change tool post
Gang tooling system
Automatic 5C collet closer
Features: 80GB program memory
Assembly
