15L Basic EDU Bundle
15L Slant-PRO CNC Lathe This product is required for the machine. $20,450.00
15L Printed Manual $23.95
Manual Oil Pump This product is required for the machine. $100.95
Lubricates ways on X-. Y- & Z-Axis. Requires manual pumping (x3) per 8 hour shift. Not recommended for unattended machining.
Light Kit for Tormach 15L Slant-PRO This product is required for the machine. $190.00
Lifting Kit for Tormach 15L Slant-PRO $395.00
PathPilot Controller for PCNC Mills and 15L Lathe This product is required for the machine. $975.00
Controller Arm This product is required for the machine. $429.00
Standard LCD Monitor This product is required for the machine. $335.00
Jog Shuttle Controller This product is required for the machine. $118.00
Quick Change Tool Post Kit for Tormach 15L Slant-PRO Lathe This product is required for the machine. $999.00
3-Jaw Reversible 6 in. Lathe Chuck (D1 Type Direct Mount) This product is required for the machine. $585.00
OD Threading Tool: CER0750K16 $66.95
Deluxe Lathe Tool Starter Kit $1,165.00
Floating Tramp Oil Collection Pillow This product is required for the machine. $15.95
Stop-Loc Setup Tool $20.95
15L Slant-PRO Extended Warranty $795.00
More Info In Stock
More Info In Stock
* Required Fields
Z-Axis Travel: 12 (305 mm)
Coolant Tank Size: 10 gallon
Motion
Spindle Power: 3 hp (2.24 kW)
Spindle Speed:
  • Low: 180 to 2,500 RPM
  • High: 250 to 3,500 RPM
Control
Optional Accessories
8-Station turret
Quick-change tool post
Gang tooling system
Automatic 5C collet closer
Features: 80GB program memory
Assembly
15L Slant-PRO CNC Lathe assembly pricing is available for $2,995
Motion
Spindle Speed:
Control
8-Station turret
Gang tooling system
Assembly
