Tormach will be closed on Friday, April 18. Regular business hours will resume on Monday, April 21, at 8:00 AM CST. Thank you for your understanding!
15L Intermediate EDU Bundle
15L Slant-PRO CNC Lathe This product is required for the machine. $20,450.00
15L Printed Manual $23.95
Lifting Kit for Tormach 15L Slant-PRO $395.00
Light Kit for Tormach 15L Slant-PRO This product is required for the machine. $190.00
Automatic Oiler Kit (230V) for PCNC 1100 / 15L This product is required for the machine. $755.00
PathPilot Controller for PCNC Mills and 15L Lathe This product is required for the machine. $975.00
Controller Arm This product is required for the machine. $429.00
Touch Screen Kit This product is required for the machine. $545.00
Jog Shuttle Controller This product is required for the machine. $118.00
Cord, Power 115 VAC 18AWG 6ft
Floating Tramp Oil Collection Pillow This product is required for the machine. $15.95
9 Inch Length Coolant Nozzle for Turret 10-Pack This product is required for the machine. $58.95
Deluxe Lathe Tool Starter Kit $1,165.00
Turret Kit for Tormach 15L Slant-PRO This product is required for the machine. $4,995.00
3-Jaw Reversible 6 in. Lathe Chuck (D1 Type Direct Mount) This product is required for the machine. $585.00
15L Manual 5C Drawtube This product is required for the machine. $253.00
5C Round Collet Set (18 Pcs.) - Inch $179.00
Huot 5C Collet Rack $47.95
Stop-Loc Setup Tool $20.95
Haimer CENTRO Precision Centering Device $835.00
5 mm Bent Probe Tip for Haimer CENTRO $98.95
15L Slant-PRO Extended Warranty $795.00
More Info In Stock
More Info In Stock
* Required Fields
Z-Axis Travel: 12 (305 mm)
Coolant Tank Size: 10 gallon
Motion
Spindle Power: 3 hp (2.24 kW)
Spindle Speed:
  • Low: 180 to 2,500 RPM
  • High: 250 to 3,500 RPM
Control
Optional Accessories
8-Station turret
Quick-change tool post
Gang tooling system
Automatic 5C collet closer
Features: 80GB program memory
Assembly
Motion
Spindle Speed:
Control
8-Station turret
Gang tooling system
Assembly
