Tormach will be closed on Friday, March 29th in celebration of Good Friday. We will reopen at 8 am CST on Monday, April 1st.
15L Slant-PRO Starter Package
15L Slant-PRO CNC Lathe This product is required for the machine. $17,245.00
15L Printed Manual $19.95
Lathe Test Piece Kit. This product is required for the machine. $0.00
Sealant, Sikaflex 1a, 300mL Cartridge, Black This product is required for the machine. $0.00
Manual Oil Pump $0.00
Lubricates ways on X-. Y- & Z-Axis. Requires manual pumping (x3) per 8 hour shift. Not recommended for unattended machining.
Automatic Oiler Kit (230V) for PCNC 1100 / 15L $645.95
Light Kit for Tormach 15L Slant-PRO $159.95
Lifting Kit for Tormach 15L Slant-PRO $329.95
Buck-Boost Transformer $229.95
PathPilot Controller for 15L Lathe and PCNC Mills This product is required for the machine. $495.00
Controller Arm $359.95
Standard LCD Monitor $279.95
Touch Screen Kit $459.95
Jog Shuttle Controller $99.95
Waterproof Mouse $24.95
Cord, Power 115 VAC 18AWG 6ft This product is required for the machine. $0.00
Cable, Monitor Power Extension 6 ft (combo male/female end) This product is required for the machine. $0.00
Power Strip 3 AC Kit for 15L This product is required for the machine. $0.00
Lathe Tool Starter Kit #1 $224.95
OD Threading Tool: CER0750K16 $55.95
ER20 Collet Chuck $39.95
ER20 Collet Set (15 Pcs.) $99.95
Plain Center Drill Set $12.95
1/16 in. - 1/2 in. Jobber Length Drill Set (by 64ths) $122.95
Deluxe Lathe Tool Starter Kit $995.95
8-Piece STFCR Stub Boring Bar Set $274.95
15L Slant-PRO Extended Warranty $795.00
More Info Stock: In Stock
Floating Tramp Oil Collection Pillow $12.95
Gang Tool Coolant Accessory Kit, 15L Slant-PRO $89.95
SprutCAM 16 OEM Lathe $895.00
Quick Change Tool Post Kit for Tormach 15L Slant-PRO Lathe $849.95
Turret Kit for Tormach 15L Slant-PRO $4,495.00
3-Jaw Reversible 6 in. Lathe Chuck (D1 Type Direct Mount) $495.00
4-Jaw Independent Reversible 6 in. Lathe Chuck (D1 Type Direct Mount) $395.00
15L Manual 5C Drawtube $209.95
5C Round Collet Set (18 Pcs.) $149.95
Automatic Collet Closer for 15L Slant-PRO $2,695.00
Stop-Loc Setup Tool $19.95
Haimer CENTRO Precision Centering Device $725.00
5 mm Straight Probe Tip for Haimer CENTRO $62.00
5 mm Bent Probe Tip for Haimer CENTRO $83.00
2 mm Straight Probe Tip for Haimer CENTRO $71.00
* Required Fields
TECHNICAL SPECIFICATIONS
Z-Axis Travel: 12 (305 mm)
Coolant Tank Size: 10 gallon
Motion
Spindle Power: 3 hp (2.24 kW)
Spindle Speed:
  • Low: 180 to 2,500 RPM
  • High: 250 to 3,500 RPM
Control
Optional Accessories
8-Station turret
Quick-change tool post
Gang tooling system
Automatic 5C collet closer
Features: 80GB program memory
Assembly
