24R ATC Upgrade Bundle
Base Price $5,994.95
Add Automatic Tool Changing capabilities to your 24R CNC Router. This 10-pocket Automatic Tool Changer allows you to hit Cycle Start and let your machine do the work from beginning to end.
What's In The Box?
  • 10 Pocket - ISO20 toolholder rack for 24R ATC
  • 1.5 Kw ISO20 ATC Spindle Assembly
    • 24,000 RPM
    • Liquid-cooled Spindle
    • Integrated Power Drawbar with Open Sensor
    • Positive Air Pressure Spindle Nose Seal
    • Maximum Tool Diameter of 1.5 inches (38 mm)
    • Maximum Tool Gauge Length of 4.25 inches (108 mm)
  • Lifting Dust Shoe Assembly, 80mm, for 24R ATC
  • 24R ATC Solenoid Control Panel Assembly
  • Filter/regulator/lubricator (FRL)Kit
  • 2 - ISO20 Tool Holders, ER20A, 30mm Gauge Length
  • ISO20 Tool Holder Wrench
  • 2 - 1/4 in. ER20 Collets
  • 30mm Wrench for TTS-ER20 Nut
NOTE: ISO20 Tool Holders use ER16 and ER20 collets which can be purchased in metric or imperial from our website - View Collets
Important! To use the ATC on machines with serial numbers RA10001 - RA10096, the Z-axis Brake Retrofit Kit is REQUIRED. If your machine's serial number is within that range, select Z-axis Brake Retrofit Kit in the package customization below.
Customize Your Package
* Required Fields
Total Package Price
Total Package Price 24R ATC Upgrade Bundle
Summary
