24R Starter Cutting Tool Kit by Amana Tools
$499.95
General purpose starter cutting tool kit for CNC routing.
Designed to handle the wide variety of cutting applications that are capable with the 24R CNC Router. This 10 piece kit is perfect for sign making, 3D carving, V-carving and working with flat sheet materials. With the 24R Starter Cutting Tool Kit by Amana Tools you will have all the cutting tools you need to start making chips.
What’s In the Box?
- Carbide Tipped V-Groove 90º x 1/2 in. Cutting Dia x 1/2 in. Cut Height x 1/4 in. Shank x 1-5/8 in. Long 2 Flute Router Bit
- Carbide Tipped V-Groove 60º x 1/2 in. Cutting Dia x 5/8 in. Cut Height x 1/4 in. Shank x 1-3/4 in. Long 2 Flute Router Bit
- Solid Carbide Up-Cut Spiral Ball Nose 1/4 in. Cutting Dia x 1 in. Cut Height x 1/4 in. Shank x 2-1/2 in. Long 2 Flute Router Bit
- Solid Carbide Up-Cut Spiral Plunge 1/4 in. Cutting Dia x 3/4 in. Cut Height x 1/4 in. Shank x 2-1/2 in. Long 2 Flute Router Bit
- Solid Carbide Up-Cut Tapered Spiral Ball Nose for 3D Carving, 1/16 in. Cutting Dia x 1/32 in. Tip Radius x 1 in. Cut Height x 1/4 inn. Shank x 5.4º Taper Angle x 3 in. Long, 4-Flute ZrN Coated Router Bit
- Solid Carbide Up-Cut Tapered Spiral Ball Nose for 3D Carving, 1/8 in. Cutting Dia x 1/16 in. Tip Radius x 1 in. Cut Height x 1/4 in. Shank x 3.6 Deg Taper Angle x 3 in. Long, 3 Flute ZrN Coated Router Bit
- Solid Carbide Point Cutting Roundover 1/8 in. Radius x 1/4 in. Cutting Dia x 5/16 in. Cut Height x 1/4 in. Shank x 2 in. Long 2 Flute Router Bit
- Solid Carbide Down-Cut Spiral Plunge 1/4 in. Cutting Dia x 3/4 in. Cut Height x 1/4 in. Shank x 2-1/2 in. Long 2 Flute Router Bit
- Solid Carbide Down-Cut Spiral Plunge 1/8 in. Cutting Dia x 1/2 in. Cut Height x 1/4 in. Shank x 2 in. Long 2 Flute Router Bit
- Solid Carbide Up-Cut Spiral 'O' Flute, 1/4 in. Cutting Dia x 3/4 in. Cutting Height x 1/4 in. Shank x 2 in. Long Plastic Cutting Single Flute CNC Router Bit with Mirror Finish
