5 in. Machinist Vise - Precision Angle Lock
5" Machinist Vise, Precision Angle Lock / Plated Handle & Kit
What’s In the Box?
NOTE: Vise keys and clamp kit sold separately.
- Vise handle
Secure stock and work material with this cast-iron CNC vise. You can quickly mount the vise with D-style side flanges into your machine’s T-slot, and its keyed stationary jaw provides a rigid backstop.
Features:
- 5 in. (127 mm) jaw width
- Constructed with 80,000 psi (550,000 kPa) ductile cast iron
- Flame-hardened vise bed
- Non-lifting moveable jaw design
- Compatible with industry-standard jaw plates
- 7/16-14 in. hole in fixed jaw for workstop (optional; sold separately)
- 1/2-13 in. holes on bottom for anchoring stationary jaw
- All machined surfaces are square and parallel within 0.001 in. (0.025 mm)
- High-quality powder coat paint on non-critical surfaces
- Machined steel handle
- Machined slots for vise keys (optional; sold separately)
- Vise bed heights are held to a .0004" (.01mm) height tolerance
Compatibility:
- 1100M / 1100MX
- 770M / 770MX
- PCNC 1100
- PCNC 770
Dimensions:
Maximum Inside Opening (w/Standard Jaws Installed) | 5 in. (12.7 cm) |
Maximum Outside Opening | 12 in. (30.5 cm) |
Jaw Width | 5 in. (12.7 cm) |
Jaw Depth | 1.5 in. (3.8 cm) |
Overall Length | 12.5 in. (31.8 cm) |
Bed Height | 2.5 in. (6.4 cm) |
NOTE: While all of our vises go through a certification process Tormach cannot guarantee that any two vises will be matched to one another and recommends shimming when using multiple vises on your machine.
NOTE: If you need a replacement jaw plate set screw for your 5" CNC Vise Precision Angle Lock, You will need a screw with the following specifications: 7/16-14 ×1 SHCS, black oxide coated or stainless steel is recommended.
