770M Advanced EDU Bundle
770M Mill This product is required for the machine. $8,695.00
770MX / 770M  Stand This product is required for the machine. $2,295.00
770M Enclosure Kit This product is required for the machine. $2,895.00
770M Chip Tray This product is required for the machine.
Door Lock Switch Kit This product is required for the machine. $295.00
Lifting Bar Kit $195.00
Automatic Oiler Kit (115V) for 770M / 770MX This product is required for the machine. $674.95
770M Mill Printed Manual $19.95
770M/M+/MX PathPilot Operator Console This product is required for the machine. $1,795.00
Flood Coolant Kit (1/8 HP) for 1100M/MX and 770M/MX This product is required for the machine. $499.95
Oil Skimmer Kit for 1100M/1100MX, 770M/770MX, and PCNC 440 This product is required for the machine. $279.95
Portable Refractometer - Coolant Tester $19.95
Power Drawbar Kit for 1100M / 770M This product is required for the machine. $1,195.00
10-Pocket Automatic Tool Changer for the 770M This product is required for the machine. $5,650.00
5 in. (127 mm) CNC Vise $499.95
Clamp Kit for 5/8 in. T-Slots (58 Pcs.) $89.95
Standard 5 in. Aluminum Soft Jaw Set $22.95
TTS™ CNC Operator Set with Tormach Tool Assistant $1,195.95
End Mill Kit for Aluminum #1 $499.95
TTS™ MiniShear .750 in. $289.95
XDET 2.522 (Mini-Shear) Insert 10-Pack $224.95
ER20 Collet Set (30 Pcs.) - Inch $249.95
5 in. (127 mm) Parallel Set $49.95
Huot ER20 Collet Rack $69.95
Modular Tension/Compression Tapping Head Kit $459.95
TTS™ Diamond Drag Engraver Kit $99.95
Passive Probe Kit $429.95
Probe Stylus, 50mm Length, 6mm Ruby Ball, M4 Thread $149.95
Electronic Tool Setter $1,295.00
Professional Metalworking Gauge Kit $379.95
770M Extended Warranty $795.00
More Info Stock: In Stock
* Required Fields
Technical Specifications
X-Axis: 14 in.(356 mm)
Y-Axis: 7.5 in.(191 mm)
Z-Axis: 13.25 in.(337 mm)
Maximum Speed: 10,000 RPM
Transmission: Poly-V belt
Spindle Taper: R8
Maximum Feed Rate
Z-Axis: 110 IPM (2.79 m/min)
Machine Dimensions
Assembly
PATHPILOT® Controller
