770M Basic EDU Bundle
770M Mill This product is required for the machine. $10,450.00
770MX / 770M  Stand This product is required for the machine. $2,669.00
770M Enclosure Kit This product is required for the machine. $3,445.00
770M Chip Tray This product is required for the machine. $469.00
Door Lock Switch Kit This product is required for the machine. $349.00
Lifting Bar Kit $230.00
Manual Oil Pump This product is required for the machine. $100.95
Lubricates ways on X-. Y- & Z-Axis. Requires manual pumping (x3) per 8 hour shift. Not recommended for unattended machining.
770M Mill Printed Manual $23.95
PathPilot Controller This product is required for the machine. $975.00
PathPilot Controller Vesa Mount This product is required for the machine. $20.00
Standard LCD Monitor This product is required for the machine. $335.00
Jog Shuttle Controller This product is required for the machine. $118.00
Controller Arm This product is required for the machine. $429.00
5 in. (127 mm) Parallel Set $58.95
Manual Operator Set (Inch) $297.00
3/8 in. Shank Edge Finder $16.95
770M Extended Warranty $795.00
More Info In Stock
More Info In Stock
* Required Fields
770M TECHNICAL SPECIFICATIONS
X-Axis: 14 in.(356 mm)
Y-Axis: 7.5 in.(191 mm)
Z-Axis: 13.25 in.(337 mm)
Maximum Speed: 10,000 RPM
Transmission: Poly-V belt
Spindle Taper: R8
Machine Dimensions
Maximum Feed Rate
Z-Axis: 110 IPM (2.79 m/min)
Assembly
770M Assembly is available for $2,995 .
PATHPILOT® Controller
Technical Specifications
Spindle Taper: R8
Maximum Feed Rate
Machine Dimensions
Assembly
