Tormach will be closed on Friday, March 29th in celebration of Good Friday. We will reopen at 8 am CST on Monday, April 1st.
770M Basic EDU Bundle
770M Mill This product is required for the machine. $8,695.00
770MX / 770M  Stand This product is required for the machine. $2,295.00
770M Enclosure Kit This product is required for the machine. $2,895.00
770M Chip Tray This product is required for the machine. $0.00
Door Lock Switch Kit This product is required for the machine. $295.00
Lifting Bar Kit $195.00
Manual Oil Pump This product is required for the machine. $0.00
Lubricates ways on X-. Y- & Z-Axis. Requires manual pumping (x3) per 8 hour shift. Not recommended for unattended machining.
770M Mill Printed Manual $19.95
Lyndex TTS™ Adapter Collet: R8 This product is required for the machine. $0.00
PathPilot Controller This product is required for the machine. $495.00
PathPilot Controller Vesa Mount This product is required for the machine. $0.00
Standard LCD Monitor This product is required for the machine. $279.95
Jog Shuttle Controller This product is required for the machine. $99.95
Controller Arm This product is required for the machine. $359.95
5 in. (127 mm) CNC Vise $499.95
Clamp Kit for 5/8 in. T-Slots (58 Pcs.) $89.95
5 in. (127 mm) Parallel Set $49.95
Manual Operator Set (Inch) $249.95
End Mill Kit for Aluminum #1 $499.95
3/8 in. Shank Edge Finder $13.95
770M Extended Warranty $795.00
More Info Stock: In Stock
PathPilot HUB CNC Simulator - Unlimited Seats $0.00
* Required Fields
Technical Specifications
X-Axis: 14 in.(356 mm)
Y-Axis: 7.5 in.(191 mm)
Z-Axis: 13.25 in.(337 mm)
Maximum Speed: 10,000 RPM
Transmission: Poly-V belt
Spindle Taper: R8
Maximum Feed Rate
Z-Axis: 110 IPM (2.79 m/min)
Machine Dimensions
Assembly
PATHPILOT® Controller
