770M Intermediate EDU Bundle
770M Mill This product is required for the machine. $10,450.00
770MX / 770M  Stand This product is required for the machine. $2,669.00
770M Enclosure Kit This product is required for the machine. $3,445.00
770M Chip Tray This product is required for the machine. $469.00
Door Lock Switch Kit This product is required for the machine. $349.00
Automatic Oiler Kit (115V) for 770M / 770MX This product is required for the machine. $755.00
Lifting Bar Kit $230.00
770M Mill Printed Manual $23.95
770M/M+/MX PathPilot Operator Console This product is required for the machine. $2,339.00
Flood Coolant Kit (1/8 HP) for 1100M/MX and 770M/MX This product is required for the machine. $589.00
Power Drawbar Kit for 1100M / 770M This product is required for the machine. $1,399.00
TTS™ CNC Operator Set with Tormach Tool Assistant $1,399.00
Modular Tension/Compression Tapping Head Kit $545.00
Manual Operator Set (Inch) $297.00
TTS™ Diamond Drag Engraver Kit $118.00
ER20 Collet Set (15 Pcs.) - Inch $118.00
5 in. (127 mm) Parallel Set $58.95
HAIMER 3D-Sensor New Generation Kit (Metric) $655.00
Metric Ball Replacement Tip for Haimer Zero Master/ 3D Sensor $61.95
3/8 in. Shank Edge Finder $16.95
770M Extended Warranty $795.00
More Info In Stock
More Info In Stock
* Required Fields
770M TECHNICAL SPECIFICATIONS
X-Axis: 14 in.(356 mm)
Y-Axis: 7.5 in.(191 mm)
Z-Axis: 13.25 in.(337 mm)
Maximum Speed: 10,000 RPM
Transmission: Poly-V belt
Spindle Taper: R8
Machine Dimensions
Maximum Feed Rate
Z-Axis: 110 IPM (2.79 m/min)
Assembly
770M Assembly is available for $2,995 .
PATHPILOT® Controller
Technical Specifications
Spindle Taper: R8
Maximum Feed Rate
Machine Dimensions
Assembly
