770M Standard Package
770M Mill This product is required for the machine. $8,695.00
Printed manual for 770M Mill $19.95
Lyndex TTSâ„¢ Adapter Collet: R8 This product is required for the machine. $0.00
770MX / 770M  Stand $2,295.00
770M Chip Tray $0.00
Manual Oil Pump $0.00
Lubricates ways on X-. Y- & Z-Axis. Requires manual pumping (x3) per 8 hour shift. Not recommended for unattended machining.
Automatic Oiler Kit (115V) for 770M / 770MX $645.95
770M Enclosure Kit $2,895.00
770M Backsplash Kit $289.95
Door Lock Switch Kit $295.00
Lifting Bar Kit $195.00
770M Moving Kit $99.95
10-Pocket Automatic Tool Changer for the 770M $5,650.00
Power Drawbar Kit for 1100M / 770M $1,195.00
California Air Tools 4610XC Air Compressor $349.95
microARC 4 - 100 mm 4th Axis $2,795.00
6 in. Motorized Rotary Table $1,595.00
6 in. Super Spacer Motorized Rotary Table $2,595.00
6 in. Tilting Motorized Rotary Table $2,495.00
4th Axis Driver Kit  for1100M, 1100MX, 770M or 770MX $200.00
3 Jaw Chuck for 6 in. (152 mm) Table $395.00
4 Jaw Chuck for 6 in. Table $395.00
2 Jaw Chuck for 6 in. Table $299.95
Flood Coolant Kit (1/8 HP) for 1100M/MX and 770M/MX $499.95
FogBuster Coolant Kit (115 Vac) for 770M/770MX $599.95
Oil Skimmer Kit for 1100M/1100MX, 770M/770MX, and PCNC 440 $279.95
Portable Refractometer - Coolant Tester $19.95
SmartCool Starter Kit $699.95
Passive Probe Kit $429.95
Active Probe Kit $1,795.00
HAIMER 3D-Sensor New Generation Kit (Metric) $519.95
Metric Ball Replacement Tip for 3D Sensor $54.95
Replacement Probe Tip $119.95
Electronic Tool Setter $1,295.00
TTSâ„¢ Touch Tool w/Digital Indicator and Box $79.95
TTSâ„¢ Touch Tool w/Mechanical Indicator and Box $49.95
Essential Metalworking Gauge Kit $295.95
3/8 in. Shank Edge Finder $13.95
Laser Edge/Center Finder (Bullseye) $159.95
Laser Edge/Center Finder (Center Spot) $129.95
Digital Micrometer (0-1 in.) $59.95
Digital Caliper (0-6 in.) $27.95
Stop-Loc Setup Tool $19.95
5 in. Machinist Vise - Precision Angle Lock $549.00
Clamp Kit for 5/8 in. T-Slots (58 Pcs.) $89.95
5 in. (127 mm) CNC Vise $499.95
4 in. CNC Vise $395.00
Saunders Machine Works Tooling Plate for 770 Mills $849.00
770 Basic Fixture Accessory Kit $509.91
Standard Fixture Plate Accessory Upgrade Kit $497.85
VersaGripâ„¢ Vise Jaws - Mitee-Bite - Compatible with 4 in. and 5 in. vises $185.00
6 in. TalonGripâ„¢ Vise Jaw Systems  - Mitee-Bite - Compatible with 4 in. and 5 in. vises $170.00
Standard 5 in. Steel Step Jaw Set $59.95
Standard 5 in. Aluminum Soft Jaw Set $22.95
SuperSoft Jaws Kit $174.95
Multi-V 5 in. Jaw Set $114.95
5 in. (127 mm) Pin Jaw Set $199.95
5 in. (127 mm) Parallel Set $49.95
Work Stop $49.95
TTSâ„¢ Diamond Drag Engraver Kit $99.95
TTSâ„¢ Rotary Broach Kit $595.95
TTSâ„¢ Saw Arbor: 1/2 in. $69.95
TTSâ„¢ Saw Arbor: 1 in. $69.95
TTSâ„¢ Machinable Blank $29.95
Spring-Loaded CNC Drag Knife $169.95
End Mill Kit for Aluminum #1 $499.95
TTSâ„¢ SuperFly Cutter Kit $164.95
TTSâ„¢ MiniShear .750 in. $289.95
Insert for Aluminum - XDET 2.522 - R0.031 $224.95
Insert for Aluminum - XDET 2.52.010 - R0.010 $249.95
Mini-Shear – .500 in. $244.95
DIJET QM Mini Modular Insert High Feed End Mill: 1/2 in. $269.95
TTSâ„¢ M6 Threaded Arbor: Short $39.95
Carbide Insert - DIJET - Unfavorable Conditions <50Rc - R:1mm - 10-Pack $94.95
Carbide Insert - DIJET - Shoulder Milling - R:0.2mm - 10-Pack $94.95
Carbide Insert - DIJET - High Hardened Steel Milling  loading= 50Rc - R:2mm - 10-Pack" loading="auto" /> $164.95
Mini-Shear – .500 in. MIT Cutting Head $239.95
Modular Insert End Mill: 17 mm $99.95
Carbide Insert for Aluminum and Plastic - Face & End Mills 10-Pack $124.95
TTSâ„¢ CNC Operator Set with Tormach Tool Assistant $1,195.95
TTSâ„¢ Metric Tool Holder Set $1,295.95
Modular Tension/Compression Tapping Head Kit $459.95
Manual Operator Set (Inch) $249.95
Manual Operator Set (Metric) $249.95
Spindle Speeder $1,895.00
G Wizard Machinist Calculator for Tormach $79.95
More Info Stock: In Stock
SprutCAM 17 OEM Standard $1,395.00
SprutCAM 17 OEM Advanced $2,495.00
TTSâ„¢ Set Screw Holder: 1/4 in. $29.95
TTSâ„¢ Set Screw Holder: 5/16 in. $24.95
TTSâ„¢ Set Screw Holder: 3/8 in. $30.95
TTSâ„¢ Set Screw Holder: 1/2 in. $30.95
TTSâ„¢ Set Screw Holder: 6mm $30.95
TTSâ„¢ Set Screw Holder: 10mm $30.95
TTSâ„¢ Set Screw Holder: 12mm $30.95
TTSâ„¢ ER Collet Holder: ER20 $49.95
TTSâ„¢ ER Collet Holder: ER16 $49.95
TTSâ„¢ ER Collet Holder: ER32 $59.95
TTSâ„¢ ER Collet Tap Holder: ER16 $189.95
TTSâ„¢ ER Collet Tap Holder: ER20 $189.95
ER20 Collet Set (15 Pcs.) $99.95
ER16 Collet Set (22 Pcs.) $199.95
ER20 Collet Set (30 Pcs.) $249.95
ER32 Collet Set (12 Pcs.) $184.95
Metric ER20 Collet Set (14 Pcs.) $214.95
Metric ER32 Collet Set (12 Pcs.) $214.95
Metric ER16 Collet Set (12 Pcs.) $145.95
Huot ER20 Collet Rack $69.95
Huot ER16 Collet Rack $69.95
770M Extended Warranty $795.00
PathPilot Controller $495.00
PathPilot Controller VESA Mount $0.00
770M/M+/MX PathPilot Operator Console $1,795.00
Standard LCD Monitor $279.95
Touch Screen Kit $459.95
Waterproof Mouse $24.95
Jog Shuttle Controller $99.95
Controller Arm $359.95
RapidTurn Starter Package $2,995.00
RapidTurn Deluxe Package $3,795.00
* Required Fields
