770MX / 770M Stand
The 770M / 770MX Stand is a heavy-duty, welded steel stand for the 770MX CNC mill that includes a coolant tank
Note: This item has a flat rate shipping charge inside the contiguous United States. This includes shipping to a US port of customer's choice for freight forwarding. Destinations outside of the US will incur additional freight charges.
This heavy-duty, welded steel stand provides a rigid foundation for your 770MX or 770M and space to safely store the PathPilot controller. Its centrally-located, rolling chip basket and coolant tank save you time between chip cleanouts and coolant top-offs (when machine is not in operation). The chip basket holds up to 50 lb (20 kg) of chips and features a fine mesh screen at the bottom of the drawer to help keep chips out of the coolant. The coolant tank holds up to 12 gal (45 L) of coolant and the system recycles/reclaims it for more efficient usage.
In addition, you can easily:
- Track coolant use with the coolant tank’s fill level gauge
- Refill the coolant tank by sliding it out from the front of the stand
- Easily level the machine with the stand’s threaded, adjustable feet
- Move the stand using common pallet jacks
Some assembly required.
- 770MX or 770M
- PCNC 770 (Series 1 through 3) without an enclosure
- Flood Coolant Kit (1/8 hp) (optional; not included)
What’s In the Box?
NOTE: Coolant pump and hoses not included.
The stand includes:
- Coolant tank
- Leveling feet
