Tormach will be closed on Monday, January 20. Regular business hours will resume on Tuesday, January 21, at 8:00 AM CST. Thank you for your understanding!
770MX Advanced EDU Bundle
770MX Mill This product is required for the machine. $20,995.00
770MX Mill package automatically includes stand, chip pan, enclosure, power draw bar and machine owner's kit. These items are pre-selected for you in the machine builder.
770MX / 770M  Stand This product is required for the machine.
770MX Chip Tray This product is required for the machine.
770MX Enclosure Kit This product is required for the machine.
Door Lock Switch Kit This product is required for the machine. $309.00
Automatic Oiler Kit (115V) for 770M / 770MX This product is required for the machine. $675.00
Lifting Bar Kit $205.00
Machine Way Oil (1 Gallon) $47.95
770MX Printed Manual $20.95
770M/M+/MX PathPilot Operator Console This product is required for the machine. $1,795.00
Waterproof Mouse This product is required for the machine. $26.95
Flood Coolant Kit (1/8 HP) for 1100M/MX and 770M/MX This product is required for the machine. $525.00
QualiChem XTREME CUT 251C $62.95
Oil Skimmer Kit for 1100M/1100MX, 770M/770MX, and PCNC 440 This product is required for the machine. $295.00
10-Pocket Automatic Tool Changer for the 770MX (BT30) This product is required for the machine. $5,995.00
5 in. (127 mm) CNC Vise $525.00
Clamp Kit for 5/8 in. T-Slots (58 Pcs.) $89.95
5 in. (127 mm) Parallel Set $52.95
BT30 Operator's Kit (Inch) $1,299.95
1/16 in. - 1/2 in. Machine Length Drill Set $195.00
End Mill Kit for Aluminum #1 $495.00
Passive Probe Kit (BT30) $465.00
Probe Stylus, 50mm Length, 6mm Ruby Ball, M4 Thread $105.00
Electronic Tool Setter with Mounting Block $1,395.00
PathPilot Software Bootable USB Drive - Recovery Media $26.95
770MX Extended Warranty $995.00
More Info In Stock
More Info In Stock
* Required Fields
X-Axis: 14 in. (356 mm)
Y-Axis: 7.5 in. (191 mm)
Z-Axis: 13.25 in. (337 mm)
Maximum Speed: 10,000 RPM
Transmission: Poly-V belt
Spindle Taper: BT30
Maximum Feed Rate
Z-Axis: 250 IPM (6.35 m/min)
Power Required: Single-Phase 115 Vac, 50/60Hz, 15A breaker
Table Size: 26 in. × 8 in. (660 mm x 203 mm)
Spindle Centerline to Machine Column: 8.6 in. (218 mm)
Typical System Footprint: 56 in. × 48.5 in. (1422 mm x 1232 mm)
Overall System Height: 88 in. (2235 mm)
Typical System Weight: 950 lbs (431 kg)
Frame
Warrranty
X-Axis:14 in. (356 mm)
Spindle Taper: BT30
Maximum Feed Rate
Frame
PATHPILOT® Controller
80GB program memory
Warrranty
Assembly
770MX Assembly is available for $2,995.
