Tormach will be closed on Friday, March 29th in celebration of Good Friday. We will reopen at 8 am CST on Monday, April 1st.
770MX Advanced EDU Bundle
770MX Mill This product is required for the machine. $20,295.00
770MX Mill package automatically includes stand, chip pan, enclosure, power draw bar and machine owner's kit. These items are pre-selected for you in the machine builder.
770MX / 770M  Stand This product is required for the machine. $0.00
770MX Chip Tray This product is required for the machine. $0.00
770MX Enclosure Kit This product is required for the machine. $0.00
Door Lock Switch Kit This product is required for the machine. $295.00
Automatic Oiler Kit (115V) for 770M / 770MX This product is required for the machine. $674.95
Lifting Bar Kit $195.00
770MX Printed Manual $19.95
770M/M+/MX PathPilot Operator Console This product is required for the machine. $1,795.00
Flood Coolant Kit (1/8 HP) for 1100M/MX and 770M/MX This product is required for the machine. $499.95
Oil Skimmer Kit for 1100M/1100MX, 770M/770MX, and PCNC 440 This product is required for the machine. $279.95
10-Pocket Automatic Tool Changer for the 770MX (BT30) This product is required for the machine. $5,800.00
5 in. (127 mm) CNC Vise $499.95
Clamp Kit for 5/8 in. T-Slots (58 Pcs.) $89.95
5 in. (127 mm) Parallel Set $49.95
BT30 Operator's Kit (Inch) $1,299.95
Electronic Tool Setter $1,295.00
End Mill Kit for Aluminum #1 $499.95
Professional Metalworking Gauge Kit $379.95
Passive Probe Kit (BT30) $439.95
770MX Extended Warranty $995.00
PathPilot HUB CNC Simulator - Unlimited Seats $0.00
More Info Stock: In Stock
* Required Fields
X-Axis:14 in. (356 mm)
Y-Axis: 7.5 in. (191 mm)
Z-Axis: 13.25 in. (337 mm)
Maximum Speed: 10,000 RPM
Transmission: Poly-V belt
Spindle Taper: BT30
Maximum Feed Rate
Z-Axis: 250 IPM (6.35 m/min)
Power Required: Single-Phase 115 Vac, 50/60Hz, 15A breaker
Table Size: 26 in. × 8 in. (660 mm x 203 mm)
Spindle Centerline to Machine Column: 8.6 in. (218 mm)
Typical System Footprint: 56 in. × 48.5 in. (1422 mm x 1232 mm)
Overall System Height: 88 in. (2235 mm)
Typical System Weight: 950 lbs (431 kg)
Frame
Warrranty
