770MX Basic EDU Bundle
770MX Mill This product is required for the machine. $23,450.00
770MX Mill package automatically includes stand, chip pan, enclosure, power draw bar and machine owner's kit. These items are pre-selected for you in the machine builder.
770MX / 770M  Stand This product is required for the machine.
770MX Chip Tray This product is required for the machine.
770MX Enclosure Kit This product is required for the machine.
Automatic Oiler Kit (115V) for 770M / 770MX This product is required for the machine. $755.00
Lifting Bar Kit $230.00
Door Lock Switch Kit This product is required for the machine. $349.00
770MX Printed Manual $23.95
PathPilot Controller This product is required for the machine. $975.00
PathPilot Controller Vesa Mount This product is required for the machine. $20.00
Touch Screen Kit This product is required for the machine. $545.00
Controller Arm This product is required for the machine. $429.00
Jog Shuttle Controller This product is required for the machine. $118.00
5 in. (127 mm) Parallel Set $58.95
BT30 Operator's Kit (Inch) $1,455.00
Metric Ball Replacement Tip for Haimer Zero Master/ 3D Sensor $61.95
Haimer 3D Sensor Kit (BT30) $579.00
770MX Extended Warranty $995.00
More Info In Stock
More Info In Stock
* Required Fields
X-Axis: 14 in. (356 mm)
Y-Axis: 7.5 in. (191 mm)
Z-Axis: 13.25 in. (337 mm)
Maximum Speed: 10,000 RPM
Transmission: Poly-V belt
Spindle Taper: BT30
Maximum Feed Rate
Z-Axis: 250 IPM (6.35 m/min)
Power Required: Single-Phase 115 Vac, 50/60Hz, 15A breaker
Frame
Table Size: 26 in. × 8 in. (660 mm x 203 mm)
Spindle Centerline to Machine Column: 8.6 in. (218 mm)
Typical System Footprint: 56 in. × 48.5 in. (1422 mm x 1232 mm)
Overall System Height: 88 in. (2235 mm)
Typical System Weight: 950 lbs (431 kg)
Warrranty
Assembly
770MX Assembly is available for $2,995 .
X-Axis:14 in. (356 mm)
Spindle Taper: BT30
Maximum Feed Rate
Frame
PATHPILOT® Controller
80GB program memory
Warrranty
Assembly
770MX Assembly is available for $2,995.
