8L Advanced EDU Bundle
8L CNC Lathe This product is required for the machine. $9,450.00
8L Lathe Stand This product is required for the machine. $1,869.00
8L Machine Stand Coolant kit This product is required for the machine. $469.00
8L Printed Manual $23.95
8L Lathe PathPilot Operator Console This product is required for the machine. $2,339.00
Deluxe Professional Lathe Tool Kit $185.00
3-Piece STFCR Boring Bar Set $174.00
5C Round Collet Set (35 Pcs.) - Inch $349.00
Interchangeable Point Live Center Set $140.00
Huot 5C Collet Rack $47.95
4 in. Precision 4-Jaw Chuck (5C Mount) $276.00
4 in. Precision 3-Jaw Chuck (5C Mount) $276.00
0XA Tool Holder Kit for 8L $297.00
Stop-Loc Setup Tool $20.95
Digital Micrometer (0-1 in.) $70.95
IP54 OriginCal Absolute Digital Calipers 0 to 6 in. $64.95
Haimer CENTRO Precision Centering Device $835.00
8L CNC Lathe Extended Warranty $695.00
More Info In Stock
* Required Fields
Spindle Nose: 5C
Control
Tail Stock
Taper: MT2
Diameter: 0.9 in.(22 mm)
Travel: 2.2 in.(55 mm)
X-Axis: 4.5 in.(114 mm)
Motion
Accessories:
Full Enclosure (Standard)
PATHPILOT® Controller
Features:
User-friendly design
Spindle Nose: 5C
Control
Tail Stock
Taper: MT2
Motion
Accessories
Available Accessories:
  • Full Enclosure (Standard)
Features:
  • User-friendly design
