8L Basic EDU Bundle
8L Basic EDU Bundle
8L CNC Lathe This product is required for the machine. $8,950.00
8L Lathe Stand This product is required for the machine. $1,795.00
8L Printed Manual $22.95
PathPilot Controller This product is required for the machine. $1,015.00
Controller Arm This product is required for the machine. $409.00
PathPilot Controller Vesa Mount This product is required for the machine.
Standard LCD Monitor This product is required for the machine. $319.00
Jog Shuttle Controller This product is required for the machine. $113.00
Deluxe Professional Lathe Tool Kit $178.00
4 in. Precision 3-Jaw Chuck (5C Mount) $265.00
5C Round Collet Set (35 Pcs.) - Inch $335.00
0XA Tool Holder Kit for 8L $286.00
Stop-Loc Setup Tool $22.95
Basic 3 Piece Indicator Set $150.00
Digital Micrometer (0-1 in.) $67.95
IP54 OriginCal Absolute Digital Calipers 0 to 6 in. $62.95
PathPilot Software Bootable USB Drive - Recovery Media $28.95
8L CNC Lathe Extended Warranty $695.00
More Info In Stock
* Required Fields
Spindle Nose: 5C
Control
Tail Stock
Taper: MT2
Diameter: 0.9 in.(22 mm)
Travel: 2.2 in.(55 mm)
X-Axis: 4.5 in.(114 mm)
Motion
Accessories:
Full Enclosure (Standard)
PATHPILOT® Controller
Features:
User-friendly design
Spindle Nose: 5C
Control
Tail Stock
Taper: MT2
Motion
Accessories
Available Accessories:
  • Full Enclosure (Standard)
Features:
  • User-friendly design
