Tormach will be closed on Friday, April 18. Regular business hours will resume on Monday, April 21, at 8:00 AM CST. Thank you for your understanding!
AF50+ EDU Bundle
AF50+ EDU Bundle
AF50+ Bandsaw This product is required for the machine. $5,995.00
AF50+ Bandsaw Owner's Kit This product is required for the machine.
Heavy Duty Flexible Roller Table This product is required for the machine. $335.00
Portable Refractometer - Coolant Tester $23.95
Blade Serpent Snakebite Metalworking Blade Coolant $38.95
* Required Fields
AF50+ TECHNICAL SPECIFICATIONS
Table Height: 21.75 in. / 552 mm
Length: 50 in. / 1270 mm
Width: 36 in. / 914 mm
Height with Saw at Rest: 36 in. / 914 mm
Height with Saw Vertical: 67 in. / 1702 mm
Motor Power: 1 hp / 0.75 kW
Capacity
7 in (178 mm) Round / 6 in x 8 in (152 mm x 203 mm) Flat at 90 degrees
Blade Speed
60 Hz: 90, 134, 195, 255 ft/min(27, 41, 59, 78 m/min)
50 Hz: 70, 110, 160, 210 ft/min(22, 34, 49, 64 m/min)
Blade Size
Blade Length 93 in. (2362 mm)
Blade Width 0.75 in. (19 mm)
Blade Thickness 0.035 in. (0.9 mm)
Features
115 Vac, Single-Phase Power
Pneumatic Clamping System
Hydraulic Feed Control
Programmable Automatic Workpiece Positioning
Cut lengths between 0.157 in – 50 in (4 mm – 1270 mm)
Up to 10 in (254 mm) per stroke
Maximum 5 strokes per part
Maximum 999 parts per program
Part countdown display
Integrated Coolant System — Tank capacity 2.65 Gal (10L)
Recycles Coolant
Portable
4 Blade Speeds
Blade Tensioning System
