Aluminum Fixture Plate, 18 in. x 8 in. x 10 mm
$39.95
6 lbs.
Mill thickness 18 in. x 8 in. x 10 mm Aluminum Fixture Plate. Designed to be Machined to suit for low-cost custom fixture design for PCNC 770
This fixture plate is made from mill thickness 10 mm aluminum plate.* Designed as a low cost, disposable option over more expensive Blanchard ground plates.
- 18.0 in. x 8.0 in. , fits working envelope of PCNC 7700 Mill
- 10 mm thickness (mill finish, not ground)
- 1/2" locating slots
*This plate is not finish ground and intended to be surfaced on the mill for final flatness.
