APPLY TOOL LENGTH OFFSET (G43)
- H~ is the tool number associated with the length offset to be applied.
NOTE: Generally speaking, the value of the H~ word should match the active tool number (T~ word).
It’s okay to program using the same offset already in use, or to program without a tool length offset (if none is currently being used).
TROUBLESHOOTING
It’s an error if:
- The H number is not an integer
- The H number is negative
- The H number is not a valid tool number
- Introduction
- Programming Overview
- Programming G-Code
- Rapid Linear Motion (G00)
- Dwell (G04)
- Set Offsets (G10)
- Length Units (G20 and G21)
- Straight Probe (G38.x)
- Absolute Coordinates (G53)
- Distance Mode (G90 and G91)
- Programming Canned Cycles
- Programming M-Code
- Supported M-Codes Reference
- Tool Change (M06)
- Feed Override Control (M50)
- Wait on Input (M66)
- Programming Input Codes
- Advanced Programming
