Automatic Collet Closer for 15L Slant-PRO
The Automatic Collet Closer for 15L Slant-PRO allows you to easily change collets and adjust clamping pressure on your lathe
Easily change collets and adjust clamping pressure on your lathe with our Automatic Collet Closer for 15L Slant-PRO. Simply thread a collet onto the draw tube, then use air pressure to adjust the clamping force. To fully automate your 15L Slant-PRO lathe, pair it with a bar puller!
Features
- Comes with everything you need to attach it to your 15L Slant-PRO lathe
- Compatible with standard 5C collets
- Fully integrated with PathPilot
- Made in the U.S.
Requirements:
- PathPilot v2.0, with a minimum upgrade of PathPilot v2.0.2 or later
- Filtered and pressure-regulated air supply (we recommend 32457 - FRL Filter-Regulator-Lubricator and 31945 - California Air Tools 4610S Air Compressor)
Learn More
