Belt Sanding Kit for PSG 612 Surface Grinder
The Belt Sanding Kit for PSG 612 Surface Grinder is a belt sanding grinder attachment that turns an ordinary surface grinder into a resourceful metal-finishing tool
The belt sanding grinder attachment turns an ordinary surface grinder into a resourceful metal-finishing tool.
Will work on other surface grinders with a three-inch taper per foot (TPF) arbor designed for hubs with ~1 inch at the large end of the taper.
- Belt Size: 1” x 42"
- Compatible with all grinders with 80 mm nose diameter and Standard Grinder Taper (1" per foot)
Learn More
