BORING CYCLE (G88)
The G88 cycle is as follows:
- Step 1: Preliminary canned cycle motion.
- Step 2: Move the Z-axis only at the current feed rate to the Z position.
- Step 3: Dwell for the P number of seconds.
- Step 4: Stop the spindle turning.
- Step 5: Stop the program so the operator can retract the spindle manually.
- Step 6: Restart the spindle in the direction it was going.
- Introduction
- Programming Overview
- Programming G-Code
- Rapid Linear Motion (G00)
- Dwell (G04)
- Set Offsets (G10)
- Length Units (G20 and G21)
- Straight Probe (G38.x)
- Absolute Coordinates (G53)
- Distance Mode (G90 and G91)
- Programming Canned Cycles
- Programming M-Code
- Supported M-Codes Reference
- Tool Change (M06)
- Feed Override Control (M50)
- Wait on Input (M66)
- Programming Input Codes
- Advanced Programming
