Electronic Tool Setter
$1,295.00
6 lbs.
The Electronic Tool Setter saves setup time and improves machine accuracy by automatically measuring and setting tool lengths.
What's In the Box?
In addition to the tool setter, items include:
  • 3 mm hex installation wrench
  • Factory inspection and certification report
  • M4 socket head cap screws (two), 25 mm long
  • Protective storage case with fitted foam lining
Quickly and accurately measure tools and job setups with the Electronic Tool Setter (ETS). In addition to setting the work offset’s Z position, you can use it to make corrections for thermal variance and even check for broken tooling. Features include:
  • Polished carbide touch plate
  • Sealed contacts
  • LED indicator light when triggered
  • Armored cable
  • Plug-and-play integration with PathPilot controller
  • IP68 rated
  • 1100MX
  • 770MX
  • 1100M
  • 770M
  • PCNC 1100
  • PCNC 770
Requirements
  • PathPilot controller
NOTE: You do not need to remove the ETS from the machine when using flood coolant.
Specifications
Sensing Logic Normally open
Repeatability 0.000078 in. (0.002 mm)
Maximum Over-Travel In +Z + .1968 in. (5.0 mm)
Parallelism Between Working Plane and Bottom Surface 0.00039 in. (0.01 mm)
