CANNED CYCLES REFERENCE
SUPPORTED CANNED CYCLES
  • G80: Cancel active canned cycle
  • G81: Simple drilling cycle
  • G82: Simple drilling with dwell cycle
  • G83: Peck drilling cycle
  • G73: High speed peck drilling cycle
  • G84: Tapping cycle
  • G85: Boring cycle – feedrate out
  • G86: Boring cycle – stop, rapid out
  • G88: Boring cycle – stop, manual out
  • G89: Boring cycle – dwell, feedrate out
  • X~ is the X-axis coordinate
  • Y~ is the Y-axis coordinate
  • Z~ is the Z-axis coordinate
  • A~ is the A-axis coordinate
Rotational axis (A-axis) words are allowed in canned cycles, but it’s better to omit them. If rotational axis words are used, the numbers must be the same as the current position numbers so that the rotational axes do not move.
The R number is always sticky — it keeps its value on subsequent blocks if they’re not explicitly programmed to be different.
In incremental distance mode (G91), when the XY-plane is selected, X, Y, and R numbers are treated as increments to the current position and Z as an increment from the Z-axis position before the move involving Z takes place; when the YZ- or XZ-plane is selected, treatment of the axis words is analogous.
TROUBLESHOOTING
It’s an error if:
When the XY plane is active, the Z number is sticky and it’s an error if:
When the XZ plane is active, the Y number is sticky and it’s an error if:
When the YZ plane is active, the X number is sticky and it’s an error if:
