Carbide Insert - Center Cut End Mill 17 mm 10-Pack
$150.15
0.3 lbs.
Only 5 left
Package of 10 Carbide insert used for the 17 mm center cut end mill.
- ISO Code/Manu. Code: QOMT0830R-M2
- ANSI Code: NA
- Type: Cemented Carbide
- Grade: VP15TF
- Comparable ISO Grade: P15-P35, M15-M35, K15-K35, S10-S30, H10-H30
- Surface Prep: PVD
- Cross Reference: Mitsubishi
- Notes: General Purpose Milling, not recommended for Non-Ferrous
