Carbide Insert: SCMT 3(2.5)1 10-Pack
$69.99
0.05 lbs.
The Carbide Insert: SCMT 3(2.5)1 is a positive iInsert with chipbreaker that is recommended for steel machining
Package of 10 SCMT 3(2.5)1 Carbide Turning Inserts. Positive Insert with Chipbreaker. Recommended for Steel Machining.
- Designation: SCMT 3(2.5)1
- Shape: Square (S)
- Clearance Angle: 7° (C)
- Tolerance: Class M (M)
- Type: Single-Sided (T)
- Insert I.C.: 3/8 in. (3)
- Thickness: 0.156 in. (2.5)
- Corner Radius: 0.016 in. (1)
- Grade (ISO): P5
- Coating: Al2O3/TiCN
- Chipbreaker: General Purpose
- Application: Steel
