CNMG 322 Insert 10-Pack
$49.95
0.05 lbs.
The CNMG 322 Insert is a negative insert with chipbreaker that is recommended for Steel Finishing
Package of 10 CNMG 322 Carbide Turning Inserts. Negative Inserts with Chipbreaker. Recommended for Steel Finishing.
- Designation: CNMG 322
- Shape: 80° Rhombus (C)
- Clearance Angle: 0° (N)
- Tolerance: Class M (M)
- Type: Double-Sided (G)
- Insert I.C.: 3/8 in. (3)
- Thickness: 0.125 in. (2)
- Corner Radius: 0.031 in. (2)
- Grade (ANSI/ISO): C6/P20
- Coating: TiN
- Chipbreaker: Finishing
- Application: Steel
