CUTTER COMPENSATION (G40, G41, G42)
It’s okay to turn compensation off when it is already off.
It’s an error if:
To program Cutter Compensation to the left of the programmed tool path (as viewed looking down on the mill), program: G41 D~
To program Cutter Compensation to the right of the programmed tool path (as viewed looking down on the mill), program: G42 D~
It’s an error if:
  • The D number is not a valid tool number, or it’s 0
