Door Lock Switch Kit
$295.00
3 lbs.
The Door Lock Switch Kit reduces risk by allowing you to lock enclosure doors during potentially hazardous machining operations.
The Door Lock Switch Kit reduces risk by allowing you to lock enclosure doors during potentially hazardous machining operations. Its high-force lock mechanism makes sure the doors stay closed, and its plug-and-play integration enables you to quickly install it on the enclosure.
  • 1100M
  • 1100MX
  • 770M
  • 770MX
  • PathPilot 2.1.6 or later
Requirements
  • Mill enclosure
What’s In the Box?
  • Door switch
  • Mounting hardware
