DRILLING CYCLE (G81)
The G81 Cycle is as follows:
  • Step 2: Move the Z-axis only at the current feed rate to the Z position.
  • Step 3: Retract the Z-axis at traverse rate to clear Z.
EXAMPLES
EXAMPLE:
This means that it’s in absolute distance mode (G90), old Z retract mode (G98) and the G81 drilling cycle is performed once. The X number and X position are 4. The Y number and Y position are 5. The Z number and Z position are 1.5. The R number and clear Z are 2.8. The following moves take place:
EXAMPLE:
This means that it’s in incremental distance mode (G91), old Z retract mode, and the G81 drilling cycle is repeated three times. The X number is 4, the Y number is 5, the Z number is -0.6 and the R number is 1.8. The initial X position is 5 (=1+4), the initial Y position is 7 (=2+5), the clear Z position is 4.8 (=1.8+3) and the Z position is 4.2 (=4.8-0.6). Old Z is 3.0.
The first move is a traverse along the Z-axis to (1,2,4.8), since old Z < clear Z. The first repeat consists of three moves:
Example code using G81cycle:
(Sample Program G81EX18:)
(Workpiece Size: X4, Y3, Z1)
N5 G90 G80 G20
N10 M06 T6 G43 H6
N15 M03 S1300
N20 G00 X1 Y1
N25 Z0.5
N35 X2
N40 X3
N45 Y2
N50 X2
N55 X1
N65 X0 Y0
N70 M05
N75 M30
