DuraKut 9000B Mist Coolant
$49.95
10 lbs.
DuraKut 9000B Mist Coolant is a nontoxic, nonhazardous cutting fluid for use with misting systems such as FogBuster and others.
What's In the Box?
- Each bottle contains 1 gal (3.8 L) of premixed, nondiluted fluid.
Use this premixed, nondiluted machining fluid for a variety of metalworking applications. The low-odor fluid extends tool life, decreases fluid disposal costs, and is:
- Suitable for all metal
- Ideal for milling, turning, grinding, sawing, broaching, and tapping applications
- Nontoxic and nonhazardous: contains no chlorine, silicones, or sulfur
- Designed to replace flooded coolants: no need for a recirculating coolant system
- Applied using mist systems and other minimum-quantity lubrication (MQL) equipment
- Misting systems such as FogBuster and others
Specifications
Recommended Usage | About 8 oz (235 mL) per 8 hours of use |
Support
Learn More
