Electronic Tool Setter
$1,295.00
6 lbs.
The Electronic Tool Setter saves setup time and improves machine accuracy by automatically measuring and setting tool lengths.
What's In the Box?
In addition to the tool setter, items include:
- 3 mm hex installation wrench
- M4 socket head cap screws (two), 25 mm long
- Protective storage case with fitted foam lining
Quickly and accurately measure tools and job setups with the Electronic Tool Setter (ETS). In addition to setting the work offset’s Z position, you can use it to make corrections for thermal variance and even check for broken tooling. Features include:
- Polished carbide touch plate
- Sealed contacts
- LED indicator light when triggered
- Armored cable
- Plug-and-play integration with PathPilot controller
- IP68 rated
- 1100MX
- 770MX
- 1100M
- 770M
- PCNC 1100
- PCNC 770
Requirements
- PathPilot controller
NOTE: You do not need to remove the ETS from the machine when using flood coolant.
Specifications
Sensing Logic | Normally open |
Repeatability | 0.000078 in. (0.002 mm) |
Maximum Over-Travel In +Z | + .1968 in. (5.0 mm) |
Parallelism Between Working Plane and Bottom Surface | 0.00039 in. (0.01 mm) |
