EZ-Puller with 3/4" Turret Compatible Mounting Kit
$715.95
3.4 lbs.
The EZ-Puller is a self-adjusting bar puller that pulls round stock up to 1.750 inch; fits 0.750-inch capacity.
With the EZ-Puller bar puller, you can change bar sizes in seconds without needing to make any mechanical adjustments. Just change the X value in your G-code program to switch to a different material size. To fully automate your 15L Slant-PRO lathe, pair it with our Automatic Collet Closer!
Features:
- Accommodates a wide range of material shapes and sizes:
- Hex Stock: Range of 0.125 in. - 1.375 in.
- Round Stock: Range of 0.093 in. - 1.750 in.
- Square Stock: Range of 0.125 in. - 1.000 in.
- Activates grippers without needing coolant or air pressure
- Automatically compensates for varying diameters (no gripping fingers to adjust, lose, or break)
- Fits 0.750-inch capacity gang and Quick Change tooling
- Provides high repeatability for less wasted material per part
Compatibility:
- 15L
