FEED RATE MODE (G93, G94, AND G95)
EXAMPLE – If the F number is 2.0, the move should be completed in half a minute.
TROUBLESHOOTING
It’s an error if:
- Inverse time feed rate mode is active and a line with G01, G02, or G03 (explicitly or implicitly) does not have an F word
- A new feed rate is not specified after switching to G94 or G95 canned cycle return level – G98 and G99
