Coolant Filter Assembly for 1500MX
$559.00
3.7 lbs.
Flood Coolant Filter Assembly for 1500MX, Clear
What's in the box:
Assembled kit with mounting bracket, mounting hardware, fittings, pressure gauges, filter housing, and filter.
Keep your flood coolant system working at peak performance and remove fine chips before they cause problems. The Tormach Flood Coolant Filter Assembly is designed to mount directly to the coolant tank and includes both inlet and outlet pressure gauges to help you know when to change filters.
