Hold to Run Switch
$645.00
0.9 lbs.
Hold to run switch (also known as a “dead man’s” switch) with 4m cable and M12 connector for use with ZA6 robot.
The switch has dual action – when depressed half-way it allows the robot to be jogged at 10% of maximum velocity. When released or pressed all the way in it engages the robots safety circuit, stopping all motion and removing motor power.
The hold-to-run switch allows the operator to override the safety input in order to jog the robot at 10% of maximum velocity.
This switch is ideal for installations where the operator must be inside the safety enclosure of the robot to train robot positions. The switch has dual action – when depressed half-way it allows the robot to be jogged at 10% of maximum velocity. When released or pressed all the way in it engages the robots safety circuit, stopping all motion and removing motor power.
Note: requires PN 51352 M12 Connector Splitter to function.
