ISO20 CNC Operator Set (Inch)
$729.95
11 lbs.
CNC Operator’s Set for the 24R ISO20 ATC.
This kit includes all the toolholders, pull studs, collets, wrenches and tightening fixture needed to get started with your 24R ISO20 ATC. Also, it is designed to hold all of the cutting tools in the Starter Cutting Tool Kit by Amana (50470). So you can spend more time making parts and less time changing bits.
Kit Includes:
50891 ISO20 Tool Holder, ER20A, 30mm, Pull Stud Included, 0.005mm Accuracy, Balanced to G2.5/30000RPM 5
32678 ISO20 Tool Holder, ER16A, 30mm, Pull Stud Included, 0.005mm Accuracy, Balanced to G2.5/30000RPM 5
30120 ER20 Collet, 1/4 in, 0.008mm Accuracy 5
31691 ER16 Collet, 1/4 in, 0.008mm Accuracy 5
31837 ER16A Collet Wrench 1
30151 ER20A Collet Wrench 1
50892 ISO20 Toolholder Wrench 1
50888 Tool Tightening Fixture, ISO20 1
