Clamp Kit for 5/8 in. T-Slots (58 Pcs.)
$89.95
21 lbs.
This versatile 58-piece kit provides an affordable range of workholding options and includes assorted flange nuts, strap clamps, studs, and T-nuts
This professional grade clamping kit is manufactured at a world class factory that produces high quality US brands. Pieces are made of IC45e steel for improved strength and all parts are case hardened or heat treated to HRC30-40. This clamping kit fits the 5/8" T-slots on the bench and knee mills mill. The clamping kit includes 24 1/2-13 studs, 6 step block pairs, 6 T-slot nuts, 6 flange nuts, 4 coupling nuts, and 6 end hold downs. The stated dimension of the clamping kit is the width at the top of the T-slot.
  • 1100MX
  • 770MX
  • 1100M
  • 770M
  • PCNC 1100
  • PCNC 770
Specifications
T-Slot 5/8 in. (15.9 mm)
Stud Size 1/2-13 threads
Manufacturer Manufactured at factory for top US brands
Material Made of IC45e steel
Hardening All parts hardened to HRC30-40
